Just now, Zodicus said:
id like to leave my pc on the left side of my set up. any company make a good case with components on the left and a clear panel on the right?
How much you looking to spend? There are a fair number of inverted cases on the market (this is the marketing term for the style of case you're referring to), though admittedly the ones I can think of off the top of my head are on the expensive side. be quiet!'s higher end cases like the Silent Base 802 usually have the inversion option (usually this is done manually by rotating the motherboard tray), and the Lian Li O11 Dynamic Evo does have options to invert it, though both of those options are $170+. There probably are some cheaper inverted cases you can find, though the cheaper ones are definitely not that common.
The first one I remember hitting the market was around $170, it was the Corsair 460X.
Feels like cases that have the option to invert are generally less expensive than ones that are only inverted, but maybe I'm incorrect. Been a while since I delved super far into the case market.
Are you wanting the back panel of cables seeable or simply want the panel flipped? Cases exist that allow you to swap the window and orientation to the other side.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Seems like a good few suggestions here
https://10scopes.com/best-inverted-atx-case/
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
I was wondering the same thing because they said components on the left and windowed panel on the right.
If all you want to do is see the back of the motherboard tray, which I suspect isn't the case, any case with interchangeable side and a window will do. For example, the DIYPC Silent BK Window (and the other 2 variants),  Zalman i4 (so the others in that series are probably the same) and the ComEZ Kingdom Storage Master are all under $100 and the sides are interchangeable if I recall correctly. For that matter, the Corsair 4000, 5000, 6000 with glass or mesh sides should also be interchangeable, although the hinged metal inner door covering the back would need to be removed.
If, however, you really want the internals of the case to also be reversed,  then look for "inverted" or "reversed" cases.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
