Posted December 6, 2023 Hello, I am planning on buying a laptop for myself for regular day-to-day office work and some gaming. I have been looking at Lenovo LOQ series laptops and I am confused between 2 specifications- A- CPU-> i5-12450H GPU-> NVIDIA GeForce RTX 4060 8GB GDDR6 B- CPU-> i7-13620H GPU-> NVIDIA GeForce RTX 4050 6GB GDDR6 Both have the same- RAM- 2 x 8GB, 5800MHz, DDR5 SCREEN/ DISPLAY- WQHD (15.6)(2560 x 1440), IPS, Anti-Glare, Non-Touch, 100%sRGB, 350 nits, 165Hz. STORAGE- 1TB, M.2, 2242 PCIe Gen4 TLC, SSD I have to choose between A and B as any other Combination will go over my budget(I am from INDIA, and my max budget is 1,00,000 INR, I cant have refurbished laptops due to the billing policies/methods I will be using). I usually use my laptop until they come apart themself. My current laptop is 4.5 yrs old. I am someone in the age range of 18-25 years. Please also keep these factors in consideration. Please help. Link to comment https://linustechtips.com/topic/1545575-selection-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 6, 2023 30 minutes ago, Tibdi said: Hello, I am planning on buying a laptop for myself for regular day-to-day office work and some gaming. I have been looking at Lenovo LOQ series laptops and I am confused between 2 specifications- A- CPU-> i5-12450H GPU-> NVIDIA GeForce RTX 4060 8GB GDDR6 B- CPU-> i7-13620H GPU-> NVIDIA GeForce RTX 4050 6GB GDDR6 Both have the same- RAM- 2 x 8GB, 5800MHz, DDR5 SCREEN/ DISPLAY- WQHD (15.6)(2560 x 1440), IPS, Anti-Glare, Non-Touch, 100%sRGB, 350 nits, 165Hz. STORAGE- 1TB, M.2, 2242 PCIe Gen4 TLC, SSD I have to choose between A and B as any other Combination will go over my budget(I am from INDIA, and my max budget is 1,00,000 INR, I cant have refurbished laptops due to the billing policies/methods I will be using). I usually use my laptop until they come apart themself. My current laptop is 4.5 yrs old. I am someone in the age range of 18-25 years. Please also keep these factors in consideration. Please help. I'd go with A. Everyday office tasks will feel about the same with either system; the GPU, however, is something you'll definitely notice with games. The CPU difference is significant, but not enough to overcome the graphics. Link to comment https://linustechtips.com/topic/1545575-selection-help/#findComment-16236180 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 7, 2023 Author 8 hours ago, Commodus said: I'd go with A. Everyday office tasks will feel about the same with either system; the GPU, however, is something you'll definitely notice with games. The CPU difference is significant, but not enough to overcome the graphics. If thinking of the long run, around 4-5 years, which CPU do you think will be better, thinking points such as heating, longevity, life of the cpu, new/upcoming applications requirements as the applications coming forward might me more heavy/ consuming. Last I searched around for CPU and GPU's was when I was buying my old laptop and am a bit out of touch to this thats why I am asking. Link to comment https://linustechtips.com/topic/1545575-selection-help/#findComment-16236797 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
