I'm looking for something that will actually play games on my sisters laptop. Some LEGO games, just not too harshly demanding steam games. I came across a laptop with a 6800. Anybody know id it;s OK, or too outdated?
Whats the minim spec for Laptop GPUs I should be looking at?
https://linustechtips.com/topic/154435-quick-help-with-laptop-gpu/
6800? you mean the AMD A10 6800 APU? they are pretty meh for gaming on a laptop you might get away with the sims or something
Something like a 640m would be ok for lower end games, but personally I would recommend higher, Laptop GPUs are generally a model down, like my 7970m, is a 7850 desktop card, an 880m is like a desktop 770
Any modern GPU will be fine.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
The gpu in a  D9T Alienware M7700 Clevo D900T
I have a laptop with a Radeon 4570m, it plays all games at 480p res, if that can play games, i am sure those can.
Le Bastardo+
Red Alert
Thats very old. I mean it will play games but it lacks power compared to modern laptops.
Any reason you asking about a GPU like that? How much is the laptop you want to buy? budget?
people seemed to miss the part where you said
"some LEGO games, just not too harshly demanding steam games"
MUST HAVE 880M !!!! ...................
anyways i cant seem to find laptops that have 6xxx APUs
it seems AMD only made 5xxx APUs for laptops
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
Nobody recommend that, only I have recommended anything and I said a 640m. If you read my post I was explaning that a laptop series card is always a generation and model behind, so 880m = gtx 770...
The OP seems to be looking at a laptop and nvidia 6800, a card that came out in 2004
OP, what budget do you have?
Le Bastardo+
Red Alert
