Do I need to do a fresh install?
Solved by SImoHayha,
IT depends. If you're going from AMD CPU to intel CPU you'll 100% need a fresh install or "refreshed install" IF you're upgrading from one Intel CPU to another you'll be fine.
just make sure to uninstall teh previous GPU drivers using DDU and reinstall the new drivers for the GPU.
Featured Topics
Magnumenforce ·
Posted in Phones and Tablets1 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
3
8
