2 minutes ago, dr_monster said:
Hey everyone, I haven't build a pc in about 20 years and feel like making a new one so here's my parts list tell me what you think
https://ca.pcpartpicker.com/list/g3ztQP
6700 XT isn't a $420 card, more like $300. Given the price range, you'd be better off with chopping in some places to go with a 7800 XT instead. Unless that's just a regional price, you could probably save a lot by going with a different card.
7700x is nice and all, but its so close to a 7800x3D.
Artic Silver 5 is obsolete, the thermal paste that comes with coolers are just as good and are non conductive.
As much as I love the NH-D15, there's far cheaper coolers like the Thermalright Peerless Assassin SE that don't warrant the price premium outside of the gucci-est of CPUs.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
It's good, but the cooler is pretty expensive, get a Thermalright PE120 for 45 Canadian Rubles instead 🙂
It's in CAD so... there does not seem to be a cheaper card than that.
Agree, he can get 7800X3D if saving a bit on a cooler and pay exactly the same total
https://ca.pcpartpicker.com/list/XqkF4M
Adjustments (slightly lower price than original spec) to upgrade:
- 7700X to 7800X3D
- 6700 XT to 7800 XT
PCPartPicker Part List: https://ca.pcpartpicker.com/list/9YrTPF
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($478.50 @ Vuugo)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($44.90 @ Amazon Canada)
Motherboard: ASRock B650M Pro RS Micro ATX AM5 Motherboard  ($131.00 @ Vuugo)
Memory: Crucial Pro 32 GB (2 x 16 GB) DDR5-5600 CL46 Memory  ($89.75 @ Vuugo)
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($124.97 @ Newegg Canada)
Video Card: Sapphire PULSE Radeon RX 7800 XT 16 GB Video Card  ($679.99 @ Canada Computers)
Case: Deepcool CK500 ATX Mid Tower Case  ($59.99 @ Canada Computers)
Power Supply: SeaSonic FOCUS GX 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($127.98 @ Newegg Canada)
Total: $1737.08
Generated by PCPartPicker 2023-11-24 10:25 EST-0500
Hello... I would like to help you here. I have been building PCs for over 30 years. This PC will be a Beast and will last you for many, many years. Let me know what you think.
If you have any questions please let me know. I can be reached here or I can be reached much quicker on Discord 24/7. Here is my Discord: Wizardsnapper#2772 I am also available if you need help before, during, or after the Build process on Discord through Voice or Video Chat.
https://ca.pcpartpicker.com/list/fwz228
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($99.68 @ Amazon Canada)
Motherboard: Gigabyte B650 AORUS ELITE AX ATX AM5 Motherboard  ($293.70 @ Vuugo)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($134.97 @ Newegg Canada)
Storage: TEAMGROUP Cardea Zero Z440 Graphene 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($125.99 @ Amazon Canada)
Video Card: XFX Speedster MERC 319 CORE Radeon RX 6800 XT 16 GB Video Card  ($659.00 @ Canada Computers)
Case: Corsair 3000D RGB AIRFLOW ATX Mid Tower Case  ($109.98 @ Amazon Canada)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($134.99 @ Newegg Canada)
Case Fan: Corsair iCUE AF120 RGB SLIM 56.3 CFM 120 mm Fan  ($29.86 @ Amazon Canada)
Total: $2066.67
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
Total: $2066.67
I'm trying to keep my budget under $2000 but thanks I'm getting good input from everyone.
I was able to switch out the PSU and Case for some cheaper options. I hope this helps.
https://ca.pcpartpicker.com/list/TM4yVW
Case: GAMDIAS ATHENA M1 ELITE ATX Mid Tower Case  ($64.98 @ Newegg Canada)
Power Supply: Corsair RM850e (2022) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Memory Express)
Total: $1976.81
Total: $1976.81
Will there be any issues with getting the gpu to fit ?
7 minutes ago, dr_monster said:
Trying to save $ where I can
https://ca.pcpartpicker.com/list/y4mYL9
I was able to get the price even lower.
I'm nit sure why you are so focused on the ASRock Motherboard. ASRock is not all that good. There are much better options that are cheaper. Also is there a reason that you picked a White Kit of RAM?
The GPU will fit in that Case, it might be a little snug but the Case is rated for a 400mm GPU and that GPU is only 340mm.
https://ca.pcpartpicker.com/list/LXtjJy
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($209.99 @ Amazon Canada)
Case: Azza Aero ATX Mid Tower Case  ($64.98 @ Newegg Canada)
Total: $1838.32
Total: $1838.32
I'm going with the TEAMGROUP T-Force Delta RGB 32 white just to save the $5
A few tweaks.
There doesn't seem much point to me using A-RGB memory modules when the CPU cooler will obstruct the memory area.
Consider a less expensive motherboard.
Consider a better quality case.
Motherboard: MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($229.99 @ Amazon Canada)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  ($129.97 @ Newegg Canada)
Storage: Lexar NM710 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($114.99 @ Canada Computers)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($139.50 @ Vuugo)
Total: $1931.84
Generated by PCPartPicker 2023-11-24 11:41 EST-0500
2 hours ago, brob said:
A few tweaks.
Total: $1931.84
Yeah just trying to decide on the case and mobo now. Definitely want something with fans included, mobo wise so many similar options though.
17 minutes ago, dr_monster said:
What about the Gigabyte B650M AORUS ELITE AX Micro ATX AM5 Motherboard?
It's an mATX motherboard so will look a bit small in an ATX case.
What are you trying to achieve with the pick? It's not a bad motherboard. It would certainly be fine for running a 7800X3D. But other suggestions are better.
Trying to find components that will all fit nicely, the msi tomahawk seems like a good pick so far. If the cooler will block the ram any recommendations on low profile ram ?
3 hours ago, dr_monster said:
Ok I think I'm Done ram seems lower now and the cooler looks like it should sit a little higher and the mobo has great reviews.
https://ca.pcpartpicker.com/user/DrxMonster/saved/dXjPf7
The list is marked private.
35 minutes ago, dr_monster said:
The beQuiet Pure Rock 2 CPU cooler may not have enough performance.
The 360 AIO would likely conflict with the GPU.
You can only use one CPU cooler.
The case does not have a front panel USB-C port.
The memory timings are high. It's not worth the savings.
You have been presented with several decent builds, why ignoring the suggestions?
Accidentally added the purerock Cooler last night, I was worried about the aio preventing the gpu from fitting. I'm taking suggestions for a few different people. So I'm kind of all over the place.
I know I can only have one cooler for the cpu.
Had a little to much beer last night lol.
