What rgb controller should i use
Do you know a good controller, i want to connect 3 thermaltake 120mm swafan ex12 fans, 1 of the 3 fans that gets sent with the corsair icue 4000c RGB, the 2 fans of the arctic Liquid freezer ll 280 RGB watercooling AIO, 1 glow strips named phanteks neon D - RGB strip Combo (40 cm) and a Sirlyr RGB Power supply cable - argb motherboard power supply cable - 24 pin and 2x8 pin. Is there a controller where i can connect all of them at the same time?
https://linustechtips.com/topic/1541668-what-rgb-controller-should-i-use/
