So for the past few days the PC I built just won't post and I've looked at multiple videos but nonthing seems to work. I did find out the ram I was using wasn't compatible with my motherboard and got new ones that are but it still won't post all my parts are compatible so I shouldn't need a BIOS update so now I'm just stuck trying to figure out what to do. Also everything lights up so I don't think its a power issue.
Its a B650M Pro RS wifi board with A ryzen 5 7600 and 2 sticks of corsair vengeance rgb ddr5 ram 32 gb and a radeon rx 7800 xt graphics card.
Here a picture with my pins incase that's the issue17001811049635041875181918875448.thumb.jpg.05126a905728744e5152ff6a939e3938.jpg
https://linustechtips.com/topic/1541007-my-pc-still-wont-post/
5 minutes ago, Pandagang said:
So I'm build my first PC and when I tried to test run it no signal was being sent to my monitor and the lights that indicate something wrong with my cpu and ram went on. But I checked on and reinstalled both and I don't see anything wrong with them no bent or broken parts all of them are receiving power so I was wondering if their might be something I'm missing.
I have a ryzen 5 7600, 2 flare X 5 ddr5 ram sticks, and a B650M PRO RS WiFi motherboard.
it can take a while the first time for DDR5 systems to boot.  If its an earlier BIOS on the board it can take up to 5-6 minutes the first time.
https://linustechtips.com/topic/1541007-my-pc-still-wont-post/#findComment-16207161
Oh ok I'll wait a while  and see if it works because I haven't been leaving it on for long.
https://linustechtips.com/topic/1541007-my-pc-still-wont-post/#findComment-16207171
