Lenovo laptop not outputting through a USB-C to Displayport cable
IproZ
Hi! I'm having issues with using a usb c to displayport cable. I bought a Dell G2724D and it arrived with a cable included so I wanted to use it but I just get no signal output to it from my Lenovo Ideapad 5 Pro 16ACH6 laptop. I've tried another laptop too but that one works perfectly. All of my drivers are up to date and it shows up as a Billboard device but there is just no output. The user manual says that the usb c port that I am plugging into supports DP 1.4.
First thing I looked for was to confirm that port actually supported DisplayPort AltMode and it appears that it does.
https://psref.lenovo.com/syspool/Sys/PDF/IdeaPad/IdeaPad_5_Pro_16ACH6/IdeaPad_5_Pro_16ACH6_Spec.pdf
No other displays give an image? Detect displays option in Windows? What does the Display section of Windows Settings show?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
Over HDMI it works fine, but with the same cable and different monitor it has the same issue. Display section only has settings for the internal display, but on the other laptop it works at full 1440p 165 Hz.
Have you been able to try a different USB C to DP cable?
What was this second laptop connected with?
It was a cheaper Lenovo IdeaPad and it was connected with the same cable. And no I wasn't able to try a different cable.
