Budget?
Do you already have a 1070ti?
I mean like a bunvha money wasted on a weak cooling solution when a 30$ thermalright assasin 120 does just as well.
Expensive board and case too when cheaper ones are at worst just as good and not hard to be even better.
https://linustechtips.com/topic/1540530-first-pc/#findComment-16203444
PCPartPicker Part List
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor  ($359.99 @ Amazon)
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($159.99 @ Amazon)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Newegg)
Storage: *Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($104.99 @ Amazon)
Video Card: *Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ Newegg)
Case: Phanteks Enthoo Pro 2 ATX Full Tower Case  (Purchased For $0.00)
Power Supply: Phanteks Revolt X 1200 W 80+ Platinum Certified Fully Modular ATX Power Supply  (Purchased For $0.00)
Monitor: *Acer Nitro XV1 XV271U 27.0" 2560 x 1440 180 Hz Monitor  ($209.99 @ Amazon)
Total: $1474.84
Generated by PCPartPicker 2023-11-13 02:15 EST-0500
https://linustechtips.com/topic/1540530-first-pc/#findComment-16203789
On 11/12/2023 at 6:11 PM, jaslion said:
Budget?
Yes I already own he 1070ti and I wanted a cooling solution that looks cool but if you think that you can configure a better system please do I am open to changing up my list.
https://linustechtips.com/topic/1540530-first-pc/#findComment-16209019
What is your purpose for this system btw. Because 64gb of ram is overkill as 32gb still is even for just games.
Else for cooling you really don't need more and you also can't even really oc these chips anyway because they are already running at their ceiling.
Also added a better monitor for a little more. Has noticably better colors and a smoother snappier pixel refresh. The lg is also still a good monitor if you want that.
PCPartPicker Part List: https://pcpartpicker.com/list/7DzQRK
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  ($211.00 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($36.90 @ Amazon)
Motherboard: MSI PRO B760-P WIFI ATX LGA1700 Motherboard  ($159.99 @ Amazon)
Memory: Corsair Vengeance RGB 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory  ($214.99 @ Amazon)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ Western Digital)
Video Card: MSI DUKE GeForce GTX 1070 Ti 8 GB Video Card  (Purchased For $0.00)
Monitor: Gigabyte M27Q 27.0" 2560 x 1440 170 Hz Monitor  ($259.99 @ Amazon)
UPS: CyberPower CP1500AVRLCD UPS  ($119.99)
Total: $1102.85
Generated by PCPartPicker 2023-11-17 11:08 EST-0500
With that 350 saved you can buy a great used gpu upgrade if you wanna game better.
https://linustechtips.com/topic/1540530-first-pc/#findComment-16209049
Total: $1102.85
I don't know much about monitors but by reading some of the reviews on the one that you recommend there seems to be a bleeding issue with the whites and blacks. I was wondering if there are any monitors in this price range that would have more dimming zones that don't bleed as much. If not then which do you think would be the best price to preformence.
https://linustechtips.com/topic/1540530-first-pc/#findComment-16210809
Well thats just ips also I linked the wrong m27q thr m27q v2.0 fixed that as well as thr m27q x
https://linustechtips.com/topic/1540530-first-pc/#findComment-16210847
I'm sorry for asking so many questions but is https://www.microcenter.com/product/5006593/intel-core-i9-12900k,-asus-z790-v-prime-wifi-ddr5,-gskill-ripjaws-s5-32gb-kit-ddr5-6000,-computer-build-bundle a good deal because I am very new to this I think it is but I don't know if it is worth it to get. That's all and thank you for your help
https://linustechtips.com/topic/1540530-first-pc/#findComment-16210977
Before you do anything can you answer my starting question?
Or better even fill this one in completly
On 11/12/2023 at 11:42 PM, AVKCOOLWONDER37 said:
Budget (Lower than what I have):
Country: USA
Games, programs or workloads that it will be used for:
Because I dont know if its good for you. I dont know the usecase or budget
Is it a good deal value wise? Yeah decently rams kinda slow cl rating wise but whatever. Cooling a 12900k sucks to do but is managable. Just need to undervolt it since asus overvolts it
https://linustechtips.com/topic/1540530-first-pc/#findComment-16211108
Around 1,000 USD
USA
I will be Using it for games like Baldur's gate, ark, starfield, very modded Minecraft, Subnautica, exe. I will also be doing some web browsing, school work, and just general usecase's
https://linustechtips.com/topic/1540530-first-pc/#findComment-16212783
9 hours ago, AVKCOOLWONDER37 said:
Around 1,000 USD
USA
Ok this makes things way more in perspective and allows me to make a way better budget optimized system with views on a gpu upgrade in the nearer future
https://linustechtips.com/topic/1540530-first-pc/#findComment-16213214
Not to rush you or sound rude but are you going to put together a system if not that's fine im just asking and if so thank you.
https://linustechtips.com/topic/1540530-first-pc/#findComment-16220110
I forgot
PCPartPicker Part List: https://pcpartpicker.com/list/7vQF4M
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  ($211.00 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: MSI PRO B760-P WIFI ATX LGA1700 Motherboard  ($178.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($89.99 @ Amazon)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ Amazon)
Monitor: Gigabyte M27Q 27.0" 2560 x 1440 170 Hz Monitor  ($249.99 @ Amazon)
Total: $985.85
Generated by PCPartPicker 2023-11-24 15:02 EST-0500
Really all you need includes a monitor not sure if that was in the 1000$ or not
https://linustechtips.com/topic/1540530-first-pc/#findComment-16220116
