Need Help With New Build
Go to solution Solved by venomtail,
8 hours ago, Jacobplayz_YT said:
do you think you could do this build in black? I tried just changing the colors but some of the parts didn't come in black, and I'm not sure if the new parts I substituted for them would work
Do you want a mostly black or a complete blackout? Here the CPU cooler and RAM have a hint of silver that I assume would shine a bit as well:
PCPartPicker Part List
CPU: Intel Core i5-13400 2.5 GHz 10-Core Processor  ($202.99 @ Best Buy)
CPU Cooler: Thermalright Burst Assassin ARGB 66.17 CFM CPU Cooler  ($23.90 @ Amazon)
Motherboard: ASRock B760M PG Lightning Micro ATX LGA1700 Motherboard  ($115.98 @ Newegg)
Memory: Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-7000 CL32 Memory  ($114.99 @ B&H)
Storage: MSI SPATIUM M371 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($39.99 @ Newegg)
Video Card: PNY VERTO GeForce RTX 3060 12GB 12 GB Video Card  ($279.99 @ B&H)
Case: Deepcool MATREXX 40 3FS MicroATX Mini Tower Case  ($49.99 @ Newegg)
Power Supply: MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Amazon)
Total: $887.82
Generated by PCPartPicker 2023-11-10 03:52 EST-0500
Country: US, Long Island
Games, programs or workloads that it will be used for: Gaming (Rocket League, Fortnite, Valorant, Minecraft) Video Editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Trying to play 1080p @144/165 Hz. Budget 1000 USD, Monitor needed (don't account into budget), Black Build Preferred
"Don't be sorry, be better"
https://linustechtips.com/topic/1540075-need-help-with-new-build/
Intel with iGPU incase you need quicksync. NVIDIA for CUDA, most likely support in most video editing software. RAM that goes BRRRR. Motherboard that seems ok for price, VRMS seem ok as well as rest of spec at a glance. Should be ok airflow in case with cooler and PSU is serviceable for the budget.
Might want to spend more on storage but that optional, merely because video files are known to eat up a lot of storage so that 1TB can go quickly. Either this 10TB HDD fits your budget or more conveniently this 4TB SSD is within your budget to round off to $1k.
CPU Cooler: Thermalright Assassin King SE ARGB 66.17 CFM CPU Cooler  ($22.90 @ Amazon)
Motherboard: ASRock B760M-HDV/M.2 Micro ATX LGA1700 Motherboard  ($97.98 @ Newegg)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-7200 CL34 Memory  ($124.99 @ Amazon)
Video Card: Zotac GAMING AMP GeForce RTX 3060 12GB 12 GB Video Card  ($249.94 @ Newegg)
Case: Deepcool CC360 ARGB MicroATX Mini Tower Case  ($57.98 @ Newegg)
Total: $856.76
Generated by PCPartPicker 2023-11-09 10:00 EST-0500
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
"Alternative"  version of @venomtail build, with a better CPU and GPU (not by a ton tho) to the expense of RAM speed
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor  (€261.60 @ Amazon Deutschland)
CPU Cooler: Deepcool AG400 BK ARGB 75.89 CFM CPU Cooler  (€34.90 @ Alza)
Motherboard: MSI PRO B760M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  (€146.00 @ Amazon Deutschland)
Memory: Patriot Viper 4 Blackout 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€37.90 @ Alza)
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€66.98 @ Amazon Deutschland)
Video Card: Inno3D Compact GeForce RTX 4060 8 GB Video Card  (€312.99 @ Amazon Deutschland)
Case: Antec AX61 ELITE ATX Mid Tower Case  (€64.88 @ Galaxus)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€119.37 @ Amazon Deutschland)
Total: €1044.62
Generated by PCPartPicker 2023-11-09 16:09 CET+0100
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($144.97 @ Newegg)
CPU Cooler: *Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler  ($17.89 @ Amazon)
Motherboard: *Gigabyte B660M AORUS ELITE AX DDR4 Micro ATX LGA1700 Motherboard  ($129.99 @ Newegg)
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($59.99 @ Amazon)
Storage: *TEAMGROUP T-Force Vulcan Z 2 TB 2.5" Solid State Drive  ($78.98 @ Amazon)
Video Card: *Gigabyte GAMING OC Radeon RX 7700 XT 12 GB Video Card  ($439.99 @ Amazon)
Case: *Deepcool CC560 ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($96.99 @ Newegg)
Total: $1028.79
Generated by PCPartPicker 2023-11-09 10:20 EST-0500
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($195.43 @ Amazon)
CPU Cooler: Scythe Kotetsu Mark 3 67.62 CFM CPU Cooler  ($27.99 @ Newegg Sellers)
Motherboard: Biostar B760M-SILVER Micro ATX LGA1700 Motherboard
Storage: Samsung 980 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($64.98 @ Amazon)
Video Card: PowerColor Fighter OC Radeon RX 6800 16 GB Video Card  ($399.99 @ Newegg)
Case: Zalman S3 ATX Mid Tower Case  ($49.99 @ Amazon)
Power Supply: Super Flower Legion GX Pro 750 W 80+ Gold Certified Semi-modular ATX Power Supply  ($74.99 @ Newegg Sellers)
Case Fan: ARCTIC P12 Silent 24.1 CFM 120 mm Fan  ($8.18 @ Amazon)
OS: OpenBSD -current WM: Polybar -- bspwm -- dmenu -- picom Components: Intel 12700KF -- G.SKILL RIPJAWS @4000 CL18 -- ASUS Dual Radeon RX 9060 XT 16GB -- ASUS ROG STRIX B760-G GAMING WIFI D4 -- JONSBO Z20 black -- ARCTIC F14 -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK -- Kingston Renegade G5 1TB and Samsung 9100 PRO 1TB Mouse: zalman ZM-GM7 Display panel: UltraGear 34G630A-B Headphones: Kawai SH-9 Webcam: Microsoft LifeCam HD-3000 Keyboard: HP desktop 320K Microphone: Trust GXT 259 RUDOX Camera: Fujifilm X-M5
Total: $856.76
Total: $887.82
