RTX 2060 super temps
Solved by Hinjima,
33 minutes ago, JustTaru said:Hey guys. Is 83c at 100% good for RTX 2060 super in a case that has very poor airflow(only 1 exhaust fan). Im planning to buy 2 more fans
83c is completely fine for long term use, its warm but not dangerous for the card. Completely fine until you get some more case fans to get more airflow, nothing to worry about
You can open the sidepanel a little or remove it completely when you do hard gaming to lower the tempratures if you worry.
