Here they are :D
http://pcpartpicker.com/user/cesar1911/saved/4FOj
or
http://pcpartpicker.com/user/cesar1911/saved/4IsR
or
http://pcpartpicker.com/p/3LVXV
which one would perform betetr and also be kind off future proof until i can afford porbably another 780 ti or just get those two 780
which one???
and pls do any modifications to the build if it will help it perform better for my money ! :D
https://linustechtips.com/topic/153802-need-help-picking-builds/
xXcesar1911Xx, on 17 May 2014 - 6:42 PM, said:
Are you going to be doing some serious rendering or just gaming?
https://linustechtips.com/topic/153802-need-help-picking-builds/#findComment-2051870
2nd choice.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/153802-need-help-picking-builds/#findComment-2051895
i agree second config is well balance, i pick #2
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/153802-need-help-picking-builds/#findComment-2052028
