Weird GPU reset issue caused by power extension cables?
Solved by Skiiwee29,
It's possible. When you add length and extensions it adds more resistance for the current. Some psu's will use 16awg cabling on higher end psus and most extensions are 18awg which increases resistance even more. You're already doing the right thing by testing directly into your PSU bypassing the extensions to test this. If it does resolve, then don't use the extensions and order full replacement cables for your PSU from a reputable manufacture.
