BSOD error with Wifi Adaptor
Solved by SImoHayha,
try uninstalling the driver then finding another driver from some other site like Lenovo or Intel, and install those drivers instead. Usually you can google the chipset a wifi usb dongle uses and use some other drive. Perhaps even try an older driver version to see if it fixes this.
Edit:1
a quick google search and overview of few pages all point towards the USB wifi device being the issue here.
you could also try bios updating the motherboard and or chipset drivers for your specific motherboard
