need help identifying this component if possible please
Solved by Heats with Nvidia,
All the markings are burnt off, so there is no chance to find out, what kind of resitor that was. But you wrote this is a stereo system. Maybe the other side has the same board and with this, the same resistor. Or is it just one device?
Maybe you can find some information about it online. A last resort kind of thing is, you just ask the manufacturer what R13 was. Occasionally they will answer theses questions.
Also please have a very close look at the other components. Such a resistor rarely dies on its own.
