How Do I Control RGB & ARGB on Asus TG H670 Pro Wifi D4
RevGAM
Because of the very annoying, some might even say malware-like, behavior of Asus Armoury Crate, I have removed it, AI Suite, and so on. As a consequence, using my RGB strip header and ARGB header is problematic.聽 I've downloaded both SignalRGB and OpenRGB. The former has not been able to do anything with those headers. I tried experimentally adding a couple of Asus devices (RGB strip and ROG LED something) but that didn't help. All I got was the two fans remained one solid color. The latter, with messing with settings, has been able to provide better control, although it's a bit odd. I've never worked with this sort of software before, aside from iCUE - which doesn't have any control over my headers despite the arrangement with Asus for Aura control (except via the lighting node in my 5000x).
Looking for good advice from the LED fans out there on how to best manage the LEDs. Is there an Asus driver I need to install? Do I need to change the Aura BIOS setting?
TIA!
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 馃槈 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.馃お馃槀
4 minutes ago, emosun said:
do none of the rgb items have their own controller?
Not the ones I currently have plugged in. The case's SP120 RGB Elites are controlled via the lighting node. I have an Akasa Vegas R7 plugged into the RGB strip header and a Zalman SF120 plugged into the ARGB header. The difference with both running the same effect via OpenRGB is significant, but I use the SP120s with the iCUE "Temperature" setting and when I choose that those LEDs turn off. No idea how to get the Akasa and Zalman to do anything with SignalRGB, and no Temperature option for the SP120s.
Do you have any suggestions?
nope , i just use ones that have their own controller so they function without software
I use OpenRGB, or I use the standalone Asus Aura app. Might be a little harder to find that one. I don't have a link, sorry.
AMD R7 5800X3D | Thermalright Frozen Edge 360, 5x TL-B12 V2
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact, TL-B14, TY-143
