Hello all,
My girlfriend bought a brand new RX6500XT and it has this strange issue where it wont render parts of the screen often in a line or in the shape of a triangle.
Also when I try to install AMD software and the drivers from it the PC blue screens. I have tried windows 11 and windows 10 and there is no difference at all.
The problem is not in the hdmi/DP port since I have swaped those too and the issue is visible in a screenshot (attached to the post) 370142501_1526160721475519_3610161126527336104_n.thumb.png.329aac5d3f32a2e07cbbec1cd5f0605f.png
https://linustechtips.com/topic/1535489-amd-rx6500xt-render-problem/
Which RX6500xt? (What board partner?)
What are the specs for the system the new gpu is in?
Why would your GF buy an RX6500xt?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Why would your GF an RX6500xt?
The GPU is from Phantom Gaming
Motherboard is x570 pro4 from ASRock
The CPU is Ryzen 5 4500 and 16gb of ram
Can you try disabling windows updates then running DDU to get a completely fresh driver install?
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
Try another gpu. If it work better, then you know what to do.
System specs below
PSU: Corsair CX650M
