Shortcut to toggle CPU turbo.
Solved by unclewebb,
10 hours ago, Hensen Juang said:which toggles CPU turbo mode on and off
Set up two profiles in ThrottleStop. One with the Disable Turbo box clear and the second profile with Disable Turbo checked. Set up two keyboard shortcuts within ThrottleStop so you can easily switch profiles while in game.
CTRL + ALT + 1 to switch to Profile 1
CTRL + ALT + 2 to switch to Profile 2
You can define the two hotkeys however you like.
Push the HotKeys button in the Options window to access the Hotkey Manager.
