Downloaded pluralinput to get two cursors and now no mice work anymore
Solved by seancogan2,
Just now, Kisai said:I have no idea why you'd do this, but you're clearly going to have to uninstall the driver, because it seems to have replaced the generic HID driver for mice.
I had a stroke of genius seconds after I posted this, and resolved the issue
(I had to press spacebar on the check box when removing driver instead of enter)
I am trying to figure out how to delete my post but I am inexperienced with this forum
