nopost no boot No POST after PC being in storage for a few months.
9 minutes ago, NinthTurtle1034 said:Hi all,
So I put my gaming PC in storage a few months as I wasn't using it a whole lot due to work being so busy. I decided to get it out of storage a couple of days ago and it's now not posting.
Components are:
- CPU Ryzen 5 5600X
- AIO: Corsair ICue H100i
- Mobo: ROG Strix X570E
- RAM: Vengance 2*16GB 3600
- SSD: Samsung 980 Pro 1TB NVME
- GPU: Gigabyte RTX 3080
- PSU HX750i 80+ plat
All I've done so far is plug in the power which makes the mobo light up but as soon as I press the power button the lights turn off so maybe it's grounding itself. I did some googling for troubleshooting steps and tried the following:
- Pulled out the GPU and SSD to make sure they're not tripping anything
- Tried clearing the CMOS, not sure if this took because I don't have a physical CMOS as far as I can tell it's just a button the back of the mobo
- Disconnected the PSU and tried a known good one of the same model (pulled it from my NAS)
Things I can't try at the moment:
- CPU repaste, I have the paste but no isopropyl alcohol until this weekend but my Amazon order of it arrives for the NAS
I'm not sure if something is shorting somehow because power does seem to be being delivered, it just dies when the power button is pressed.
Or maybe the liquid in the cooler is no longer liquid and needs heat to start flowing but I'd have thought it'd at least POST under that circumstance.
Or maybe the cooler leaked liquid and friend something, I saw a Toms Hardware post where that happened to someone.
Does anyone have any idea's or suggestions for next steps?
Repast it. Wipe it off with a clean towel, elbow grease and maybe a tiny dab of water. It's a metal surface, you can't hurt it. The paste wipes off, it's not some magic unicorn poop that needs the virginity of a princess to take off.
When you put it in storage, how did you store it? Did you do anything to it or just place the case in a Self Storage? If you didn't do anything, then maybe it got jostled? Loose wire? I'd recheck each and every connection.
Was the storage climate controlled?
