Help with an upgrade
Go to solution Solved by filpo,
1 minute ago, Domigol said:
Storage (need new)
for storage I'd get a p5 plus 2tb Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (CT2000P5PSSD8) - PCPartPicker
2 minutes ago, Domigol said:
RAM: 2x 16GB Crucia
what speed is this ram running at?
MB: Gigabyte h170 gaming 3 (upgrading)
- CPU: Intel i5 6600K (upgrading)
PCPartPicker Part List
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  (€208.92 @ Galaxus)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  (€38.29 @ Amazon Deutschland)
Motherboard: Asus TUF GAMING B660-PLUS WIFI D4 ATX LGA1700 Motherboard  (€182.52 @ Galaxus)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€107.25 @ Amazon Deutschland)
Case: Deepcool CC560 ARGB ATX Mid Tower Case  (€64.90 @ Alza)
Power Supply: Thermaltake Toughpower GF A3 - TT Premium Edition 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  (€124.90 @ Amazon Deutschland)
Total: €726.78
Generated by PCPartPicker 2023-09-30 10:06 CEST+0200
Budget (including currency): around 700€ (flexible budget)
Country: EU - Slovenia
Games, programs or workloads that it will be used for: Work (CAD, Blender, Rhino, Arhicad, Adobe programs, Twin motion, ...); Games: BG3, Dying light, CIV, Minecraft ...
Hi, I'm a relative amateur in the pc building community, and would appreciate your help with a small upgrade :3
I'm currently running an 8yo system i built myself and upgraded trough the years, ands its starting to act up.
Current system:
- GPU: GTX 1070
- MB: Gigabyte h170 gaming 3 (upgrading)
- CPU cooler: Arctic Freezer i11
- RAM: 2x 16GB Crucial
- PS: system power 9 - 600W (i probably need to upgrade?)
- Case: Cooler master elite 430 black
- Storage (need new)
Lately I've been running in to some performance problems mainly limited my my CPU, and my motherboards audio is completely dead.
My current plan is to upgrade my CPU and Motherboard with new drives, and later down the line getting a new GPU (the 1070 is serving me well for now). Planning for a new GPU probably means ill need
a new power supply as well. (i would love to try VR and get a ultrawide monitor at some point)
What decent CPU would you recommend for weekend gaming, and cad/3d work. And what motherboard should I buy, I would love to have at least 2 PCI-e slots, and at least one nvme slot preferably 2.
And what nvme ssds and normal ssds do you recommend. ( i currently have a 5yo 250gb ssd, and a 750gb hdd, they are both running out of space).
Also is the cpu cooler still adequate?
Thank you for all the help, i appreciates it :3
https://linustechtips.com/topic/1533680-help-with-an-upgrade/
Storage (need new)
RAM: 2x 16GB Crucia
Total: €726.78
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1533680-help-with-an-upgrade/#findComment-16153141
my ram is running at 2133 MHz
Then I'd also get a ram upgrade with the build that I linked above
G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (F4-3600C18D-32GVK) - PCPartPicker
Total: £1040.95
https://linustechtips.com/topic/1533680-help-with-an-upgrade/#findComment-16153149
But you don't need that 1050W psu now. Not sure you'll need it later.
And if you buy new Ram you might just as well consider DDR5 (and a DDR5 board). Cheap DDR5 perf is similar to expensive DDR4, so you can go cheap.
You could probably keep your old case.
1 hour ago, filpo said:
I don't understand those ubiquitous F cpu recommandations. At least mention that a non-F can be helpful. Do you carry a spare tyre in your car ?
Edited by leclod
If you don't quote us, we won't know you answered
https://linustechtips.com/topic/1533680-help-with-an-upgrade/#findComment-16153183
Well a 12600k is about 50 euros more for an igpu
Ddr4 and ddr5 perform basically the same in games anyways
9 minutes ago, leclod said:
But you don't need that 1050W psu now. Not sure you'll need later.
Ye but for only 120 euros? It’s a steal. I’d just get it now and not worry about it later
Total: £1040.95
https://linustechtips.com/topic/1533680-help-with-an-upgrade/#findComment-16153190
Here I see 21 more (10%). And a 13400 might be a better choice than the 12600KF anyway.
For a similar price I'd go with the newer plateform
Edited by leclod
https://linustechtips.com/topic/1533680-help-with-an-upgrade/#findComment-16153199
