A Screen For my Case
Solved by venomtail,
Outside of putting in a screen inside the case among components, you either have a case tat's compatible with a screen or put a screen into the 5.25'' bays.
You could buy a case with a built in screen or or buy a drive bay screen instead. Though seems like your case supports neither. You'll either have to fully custom mod the cable or buy a different case that suits either options.
A third is replacing the glass panel with a half transparent screen as I've seen in others, but expensive and mostly custom DIY as well. For sale and DIY:
