I have a question that needs answering Logic based.
I need to make a circuit that has 3 inputs (A.B,C) and 1 output
It can only use 3 gates ,Nand only Doesnt matter how many the inputs the nand has.
Output is high when:
A and B are high or
C is high
Only b is high
Calculated a truth table for it but cant make the circuit. Can anyone help me?
https://linustechtips.com/topic/153213-help-with-logic-question-electronics/
try to explain it better with no lines skimping
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
I think this will work for you:
Either of them will work, but the 2nd is kinda cheating because you should OR the output.
I know the 1st uses 4 gates, but you can't do it like that with 3 NAND gates (unless I'm missing something)
HTTP/2 203
Cheers man  will check tomorrow to see if it works :) .Can do jk flip flops and 8 bit counters just couldn't get my head round this thanks :)
By the way, while you said it needs to react to B on its own, if either A or C are pressed as well as B, it will go high anyway so it doesn't matter.
I have updated my original post because I realised an error:
HTTP/2 203
