Hello linustech audio gurus i looking for a new headset wireless because my logitech g930 is falling apart after 5 years of service .. what u guys think better go with a sennheiser rs 180 or a Steelseries H right now im more keen on the Steelserie one beacuse of the possibility to swap the battery that is a big plus for me im tired of plug and charge to be honest ...but the question is how is the quality in comparison with the Rs 180 ?? i use this set up most for music and podcast and also movies ...if there are better choice by all means .. no worries about wire i allready own the M50 so im covered with that  ;)
thanks  :D
https://linustechtips.com/topic/153130-wireless-headset/
Get another G930. Logitech is flawless.
Corsair 230T Black with red LEDs • AMD FX-8350 4.0GHz 8-Core • Cooler Master Seidon 120V 86.2 CFM Liquid CPU Cooler  Asus M5A99X EVO R2.0 ATX AM3+  Kingston HyperX Genesis 8GB (2 x 4GB) Kingston HyperX Fury 8GB (2 x4GB)  NVIDIA GeForce GTX 1060 6GB • Corsair RM 650W • Windows 10 • Logitech G403 + G810 • Audio Technica ATH-TAD300 • 1TB Seagate HDD x 2 256GB SanDisk SSD
https://linustechtips.com/topic/153130-wireless-headset/#findComment-2044993
They are not, get over it.
On topic:
Corsair Vengeance 2100 are good headsets for the price.
https://linustechtips.com/topic/153130-wireless-headset/#findComment-2045019
On topic:
Corsair would be my second choice, but Logitech has served me for years and has never failed me. I have had the same G330 for 6 years now.
https://linustechtips.com/topic/153130-wireless-headset/#findComment-2045026
The Sennheiser will undoubtedly sound better than the SteelSeries, but the SteelSeries has a microphone so I guess you have to pick your poison. As for charging, you don't have to plug the RS 180 in, just set it on the base station to charge.
https://linustechtips.com/topic/153130-wireless-headset/#findComment-2045241
