PSU - Max Drives on Single Cable?
Your limitation is the headers on the power supply (if it's modular psu), where each pin is rated for at least 9A ... if it's not modular, it's the actual cables which can do around 10-14A without small enough voltage drop due to wire resistance
The headers have a single 12v and a single 5v wire.
A classical hard drive will pull around 1A from 12v and maybe 0.6A .. 0.75A from 5v , but will pull maybe 2A for a short period (a few seconds) when the drive starts and spins up the motor.
A SSD uses no 12v, but uses 5v instead. When idle and reading files, it's mostly low power, typically under 1w (0.2-0.5A on 5v) , but when writing A LOT of data, the power consumption could go up to 8-10 watts (2A on 5v)
So it would best to not use more than 4 SATA or molex connectors on a single chain of connectors. It would be safe to use all four on a chain, but if you can, would probably be better to use only 3 per chain.
