I recently went to upgrade my 5600X to a 5900X and I can't get bios code 99. I've tried booting with one gpu, with only the boot drive attached, checked all the cables, cleared CMOS ( button and removed battery), and 3-4 different bios versions. Every time the 5600X will boot just fine, the 5900X will not. I tried the 5900X in another motherboard and it booted first try. Exchanged the 5900X and got another one and it still gets stuck on the same code.
Is there anything else left to try/does anyone have any thought on what is going wrong. On the display it will show the Aorus splash screen and will not let me into bios, will just go to the "American Megatrends" splash screen, but gets stuck without any text under it, whether I try to go into bios or let it boot.
Specs
CPU: 5900X
Mobo: X570S Aorus Master
GPU: 3080x2 + 3090
32gb of ddr4 3600 (Gskill Royal)
PSU: 1600 watts
Edit:
If you have this issue, just try the Q-Flash Plus first. It worked for me (even with the same BIOS version i started with).
Edited by Coolbule
Solution
https://linustechtips.com/topic/1529865-5900x-wont-post/
Welcome to the forums!!!
Clear CMOS when you swap CPUs? You did this already never mind.
Unplug any unnecessary peripherals plugged into the motherboard to see if you can get it to POST.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16124967
I found a few threads on the Internet with similar issues, but nothing really helpful. It is sometimes a bad CPU, sometimes a bad motherboard and most of the time the issue gets unresolved.
First thing, I'd contact Gigabyte's support to see if they know what is going on. Maybe they have a solution.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16124973
Specs
CPU: 5900X
GPU: 3080x2 + 3090
PSU: 1600 watts
Why the switch from one 5600X to two 5600X glued together? Productivity, rendering?
As for the CPU issues; how did you update the Bios? From the Bios or from Windows?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125027
5150MHz on the 5900X is faster than 4850MHz on the 5600X 😄
5900X is a beast. At stock its kinda sucky though.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125071
Well, I asked the author of the thread.
I know very well what a 5900X, had it on my system till about 2 months ago. Replaced it with the 5800X3D and now it sits in a box.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125221
I run it for game servers and stuff so just wanted more cores....
I updated it through the BIOS, so on a thumb drive and whatever "bios update utility" gigabyte has.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125228
I only have a display keyboard and mouse in that PC to begin with
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125230
Gigabyte told me it's the CPU because its "Super IO Initialization" (code 99), but I've tried 2 5900X at this point and their failure rate is <.7% so I don't think i'm that unlucky.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125233
Fair enough.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125235
Can you test with only the most necessary hardware? Just to get it to boot, meaning no storage, just 1 RAM stick, one GPU, no case front panel IO connected, ...
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125298
Found another thread that had this entry about code 99 :
What is code 99 on aorus master x570?
"Qcode 99 is "Super IO Initialization" and IO meaning anything connected to the board by any interface is not initializing. If you have just built the system, then it is saying a device is not connected properly or there is a lack of power to a device causing the IO error.
It's strange that they concluded that the CPU is faulty with an error that says there is a bad connection. It is not impossible, I still think it is weird.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125667
Agreed. But with it booting with the 5600X it makes it even more weird to me. Wouldn't/shouldn't both run into the same issue?
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125777
I'll try that tonight after work. I've unplugged all except 1gpu, boot drive, and front panel. I'll try without front panel IO also next.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125779
It should be that way. But since it is a weird issue.. this can be part of the weird too.
One possible explanation is that the BIOS uses different code for different CPUs (that is normal) but only the code for the 5900X is defective.
I'd normally recommend testing all your components one by one in another computer but I don't think it will accomplish more than what you already tried.
You know what they say ? If it is a weird issue without apparent cause, it is usually the motherboard or the PSU that is at fault. The motherboard seems to be good at some point. But did you try using another PSU ? No need for 1600W, just a 750W should be sufficient for a basic test. It shouldn't be the PSU, but at this point, why not test it ?
Good luck !!!
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16125807
Good luck !!!
So it turns out.... Q-Flash Plus does something their regular flash doesn't. Painfully removed everything but the 24 pin from the motherboard, q-flash + with a usb stick (on the same version BIOS i started on) and it booted up first try.
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16132382
I wasn't aware that Gigabyte's Q-flash plus was doing something different from regular Q-flash (from the BIOS menu). Thanks for sharing the info 🙂
https://linustechtips.com/topic/1529865-5900x-wont-post/#findComment-16132856
