I rebuilt my pc with a cpu upgrade and decided to build a sleeper for my second custom build, currently running dual boot Mint Linux and Windows 10. I ended up cutting out the bottom of the PC and attached a custom plate to mount a radiator and new feet, thankfully everything else fit fine over than having to use a small form factor power supply to fit the 80MM rad. I'll include the V1 of the build where I tried using a 5.25in drive bay pump/reservoir but the pump ended up being really loud, the cables were to long and I ran into problems with air flow and cpu temps randomly skyrocketing. The IDE drives should be working (in windows) but they were seized when I first tried them but I was able to open them up and break the motors free, than I damaged the cable at some point so I have to replace that. Also the case with a floppy drive along with the IDE drives but I don't trust those cheap sata to IDE adapter boards. There are couple more things I would like to do with the storage situation but I'll deal with that when it becomes more of an issue lol. The last pic is my old build.
CPU: Ryzen 7 5700x
Motherboard: ASRock B550M Pro4
RAM: Trident Royal Z 64GB (4x16 GB) DDR4 3200MHz
GPU: GeForce RTX 2080 SUPER
Case: Old Beige Thing
https://linustechtips.com/topic/1529856-finished-enough-sleeper-pc/
kinda like the old thing better sorry 🤷‍♂️
maybe because everyone and there mon has that case...
