Hey guys
I am building my first PC and i need your opinion about the configuration
Read the whole post before answering
  • Asus Radeon R9 270 2GB DDR5
  • AMD FX 6300 6-Core Processor
  • MSI 970A-G43 32GB DDR3
  • Corsair 8GB DDR3
  • Seagate 1TB Sata HDD
  • NZXT H440 ATX Mid Tower Case Chassis
  • Digisol 802.11N 150Mbps Wireless PCI Adapter
  • Corsair Builder Series CX500 Power Supply
  • BenQ G2025HDA 20 inch Widescreen LCD Monitor
  • Logitech Gaming Combo G100
  • Cooler Master Hyper 212 Evo
I am not an SSD speed freak but I will upgrade in the future
First of all-How's my build ?
Can I do a little OC with the 121 evo ?
Can you tell me an estimate of the power consumption of this rig ?
Thanks In Advance
https://linustechtips.com/topic/152934-final-checkmy-first-build/
seems good but a few questions
Do you need the wifi adapter?
Are you sure those are the peripherals you want?
You may be overpaying on the case
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
Yes I do need a wifi adapter
Can you suggest some peripherals ?
I don't think i am overpaying every thing is in my budget
peripherals are personal and those things seem good, the selection seems solid
My Rig
Total: $2074.22
60000 Rupees (about 1000 Dollars)
EVERY SINGLE TIME I think that someone mentioning rupees is making a Zelda joke. I'm pretty sure I'm public enemy #1 in India for being slightly insensitive.
Are you sure you want a TN? They don't have very good contrast.
- "some salty pretzel bun fanboy" ~ @helping, 2014
- "Oh shit, watch out guys, we got a hopscotch bassass here..." ~ @vinyldash303
- "Yes the 8990 is more fater than the 4820K and as you can see this specific Video card comes with 6GB" ~ Alienware 2014
H440 is priced over 10000RS... or 165-180$ whereas it should be around 120$
Yes you can OC reasonably with a Hyper 212 EVO
If you could get a Cooler Master Case such as N400... you could go up to an FX8320
I am not sure about digisol ~ go with a netgear/ TP link/ Intel WiFi adapter.
You could potentially go with a lower cost case, and upgrade a few other things... unless you have your heart set on that case.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
What Do you mean by TN ?
The H440 is 8000 Rupees on primeABGB
http://www.primeabgb.com/nzxt-h440-atx-mid-tower-case-chassis-cabinet.html
That's okay ~ but a Cooler Master N400 is just 3450RS... you can upgrade your CPU and GPU with another 4000 RS... and it seems you have not added the price of an original windows 8.1 64bit in your budget.
I already Have Windows 8
I am set on that case :) !
There are two different kinds of monitor panels.
TN sometimes has higher refresh rates, but they have bad contrast, which means that they don't have good color.
IPS is the other kind, and usually doesn't have high refresh rates, but has MUCH better color.
Unless you're a pro gamer, people usually prefer IPS by a long-shot (including our overlord Linus)
Let me do some research .
This is going to be a little out of order, but here goes:
CPU:  FX8320 10,811
Motherboard: Asus M5A97  7,550
GPU:  Asus R9 280X  23,699
Power Supply: Corsair CX600 4,230
SSD:  120GB Kingston V300 5,299
HDD: 1TB Seagate 3,915
CPU Cooler:  Hyper 212 EVO 2,515
Case:  Antec V1     2,699
Here is a nice IPS Panel Monitor that I found:  Aoc 21.5" IPS Full HD Monitor 8,350
69,000 or so just using my head.
This is 9,000 Rs. over budget, you could probably save an additional 3,000 Rs. if you buy a CPU + motherboard bundle, they are all currently out of stock right now though.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
