Hi all,
I am looking to purchase a new CPU, from the Ryzen 5 2600 for about £120 (USD$150 ish).
I am stuck between the Ryzen 5 5600X, Ryzen 5 5600, Ryzen 5 5600 and Ryzen 7 3800X.
Would going with Ryzen 3000 be a deal breaker for bang for buck compared to 5000?
Which CPU should I go for?
Thanks,
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/
Can you afford a 5700X?
Skip the 5600G and the 5500.
The 5600 and 5600X have about the same performance, out of those two get the cheaper one.
The 3800X holds the price, but it's not worth spending over a 3700X and the 5700X beats them both.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114833
that depends,
it's hard to know when all we know is your current CPU and the potential ones you're planning
what's going to be/is the use case of the PC?
and what's your motherboard? some barely handle 5600x
current PC:
PC configs I used before:
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114834
Ryzen 5600 at 120 pounds on Amazon is probably good choice.
If you want something with integrated graphics,  AMD Ryzen Pro 4750G is around $165 on eBay and is better than 5500 or 3xxx processors. Has higher stock frequencies.  5650G is around $170
5600 and 5600x would be better because you have pci-e 4.0 lanes and you have more L3 cache but they're a bit more expensive.
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114845
20 minutes ago, podkall said:
that depends,
The main uses is simulation gaming and racing games, like MSFS2020 and Forza Horizon 5, with some Cyberpunk thrown in as well
I have an ASUS B450F Gaming II
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114846
that one is quite a good Motherboard, it probably can handle even some faster than 5600x CPUs
current PC:
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114848
go for this, or 5700x if it isn't too expensive
current PC:
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114849
How far are you in terms of budget to get a 5800X3D? The performance delta between it and 5700X (5800X is the same CPU, it just has a higher power limit allowing more boost on stock settings) in a lot of simulation title is night and day. Here's Assetto Corsa Competizione for example.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114903
You won't believe, I just watched a video about the 5800X3D in racing sims compared to a 5600X...
https://linustechtips.com/topic/1528616-help-with-cpu-purchase/#findComment-16114953
