Hi guys,
So recently out of nowhere I turned on my PC and it took around 10 minutes just to post, once its on it runs just fine but I've noticed my hard drive is no longer connected. I've checked my disk management and it comes up with "Disk 0 Unknown not initialised" when i try to initialise it i get an error message saying "A device which does not exist was specified.". I have also tried unplugging all connections to do with my hard drive and giving them a quick wipe, this worked and my hard drive was connected again and i could access everything on it but once i shut my computer down again and turned it back on i had the same problem. If anyone could help me that would be greatly appreciated!! also my computer is around 4 years old.
These are my specs.
CPU: AMD Ryzen5 3600
GPU: 6GB GTX 1660 Ti Gigabyte gaming OC
CPU DeepCool GAMMAXX GT RGB
Motherboard: Asus Prime B450-PLUS
SSD: Kingston A2000 NVMe™ M.2 500 gb
RAM: 16g kit (8gx2) 2400 corsair vengeance lpx (black)
Hard Drive: Seagate 3.5" BarraCuda 1TB
Power Supply: Coolermaster MWE 80+ Gold Fully Modular 650W
Case: DeepCool EARLKASE RGB White V2
Single Fan: Coolermaster MasterFan MF140R RGB
https://linustechtips.com/topic/1527859-hard-drive-undetected/
You can try connecting it to a different SATA port and maybe booting into a Live Linux environment to see if you can get any data off of it that way, but it really sounds like your drive just died. If you care about the data on it, take it to a data recovery specialist, just know they won't be cheap.
https://linustechtips.com/topic/1527859-hard-drive-undetected/#findComment-16107105
Sometimes you can freeze the hard drive to make it work long enough to backup some data. I have done it many years ago and it worked. Not sure if it still works with newer tech
Quote
  • Place the damaged hard drive inside a ziploc freezer bag, so that no moisture gets in. (Use two or even three bags, and note that the bags do NOT need to be isotherm.)
  • Place the wrapped hard drive in the freezer
  • Leave the hard drive in the freezer for at least 12 hours
  • Then connect the drive to the computer and start copying data
  • At some point, the hard drive will fail again. When it does, redo the procedure until all data is copied or the drive dies.
https://unix.stackexchange.com/questions/112050/recovering-data-from-a-damaged-hard-drive-the-freezer-trick#:~:text=The crux of it is as follows (but,the computer and start copying data More items
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1527859-hard-drive-undetected/#findComment-16107139
Freezing can only help if it's the bearing, or some specific head problem (as far as i know, it won't help with logical, or PCB problems )
Do note, that with any other problem, it can lead to scratching the platters… and data loss.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
https://linustechtips.com/topic/1527859-hard-drive-undetected/#findComment-16107175
In that case, freezing should be a last resort.
Main Gaming Machine
https://linustechtips.com/topic/1527859-hard-drive-undetected/#findComment-16107200
