I’m in the process of getting my backup PC working again. I recently bought a new CPU (Intel i5-13600K) and a motherboard to go with it (MSI Pro Z690-A DDR4). And after replacing the parts, the CPU light turns on for half a second and instantly shuts down.
I have stripped the PC down to barebones just CPU, heatsink, and a stick of ram(have tried without the ram as well). After I am getting the same issue. These are brand new parts so wouldn’t expect a fault in them already. I have also tried swapping out power cables, PSU, heat sink, and have made sure the motherboard drivers were correct via FlashBIOS.
I am at a loss and wonder if I just got a faulty motherboard, but a visual inspection looks okay.
Any help would be great.
https://linustechtips.com/topic/1527134-cpu-restart-loops-at-cpu-debug-led/
IMG_5345.mov
No 600 series boards have native support for Intel 13th-generation chips. For your particular one, you'll need to have at least BIOS version 7D25v17 to boot.
https://www.msi.com/Motherboard/PRO-Z690-A-DDR4/support
Use BIOS flash back if you need to. Refer to your motherboard manual for steps on how to use that feature if available.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
I have tried flashing it from multiple different versions &D25v17 and up.
When using a small USB2 stick, it flickers for like 30 seconds and then shuts off (The signifying thing to say it is done), however, after restarting I get the same startup issue.
When using a larger USB3 stick, it flickers for like 3+ hours and then shuts off, and I get the same startup issue.
Would you know if I am just BIOS flashing incorrectly? I have tried following the MSI step-by-step
