Are Wireless antennae worth it?
Ps_domingo
I've been looking around the market for something to increase the range and reliability of my current router (Asus AC-66u) as it does cover my house so well.
SO I found these two:
http://www.amazon.com/ASUS-WL-ANT191-9dBi-Wireless-Antenna/dp/B00CVU3XMO/ref=pd_ybh_2
and
http://www.amazon.com/Asus-WL-ANT-157-Antenna/dp/B005UBNJ48/ref=pd_ybh_4
So my question is, do these things even work?
Another router is out of the question and a repeater is janky as hell.
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
Why is a repeater janky?
What about a powerline wifi plug, they work really well
I dont know about those antennae specifically but they can make a difference in extending range
Well that second one is a directional antenna. IT could drastically improve reception if you keep the directionality in mind
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
its kinda complicated
larger antenna require  more power
but it should be clean and not noisy
not sure how good the amps are on the asus routers
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
Signal cuts of pretty often. Defeats the purpose of the repeater.
I cant do powerline cause the First floor is on a different breaker as the second floor.
I'm guessing its pretty beefy since the stock antenna is pretty beefy to begin with. :)
Care to elaborate on "complicated?"
What I was thinking was using the second one to direct the signal to my room and use the other two to increase range downstairs. :)
get a cheap n router and use it as an access point . i had a tplink antenna big antenna,the router didn`t had the power to amplify it at max dbi.but it did improve the range a bit but the speed,no
Sadly I wont be able to route an Rj45 cable. :| I would have to redo my ceiling to do that. =))
Cables cant be exposed as much as possible.
