Not really no. Might lower temps a little, keep the dust off. Otherwise it's just for looks.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
It looks fancy
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
I agree with you, that it increases temps. It is however useful in really dusty places. If you are looking for the best motherboard flr the price (in terms of connectivity and stability) i suggest the asrock z97 extreme6.
Samung Tab S 8.4
adds the bling bling, other than that, NO, it's useless, they say it lowers the temps somehow , but i don't believe it
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
Good points about the dust, I didn't think of that.
Cheers for the recommendation :) When I get my exams over with I want to do another build so will consider this for sure.
It looks fancy
Whole list of benefits
  • Looks good
  • Improved aesthetics
Hopefully that helps you understand the 'benefits'.
Yeah I kind of guessed this was the case, it does look good but other than that I guess the marketing guys want to pretend there is actually a performance increase
If you use the included fan it may improve temps a little bit. Otherwise, no
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
I used the ASUS Sabertooth P67 during the Sandy Bridge era and the only advantage I ever saw to the thermal armor was if I ever slipped with a screwdriver. The thermal armor can protect the traces on your PCB. Other than that, it's worthless. I came to miss seeing all the circuitry plus the Sabertooth and Formula are overpriced.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
Minimizing the dust collection on the surface of the PCB by placing a raised portion above it, you create a pocket of air that can heat up or cool down the PCB more effectively without the obstruction of dust acting like insulation. The benefits of this design go to enthusiasts using max airflow setups{front fans,bottom fans,top fans,rear fans}(because they remove the potential of hot(pockets) air build up). So my opinion is that its a good design, just not for everyone. At least that's how i deduce the situation using bits of thermal expansion, aerodynamic cooling, surface area retention and other sciences jumbled up. Cheers!
It does absolutely diddly squat besides add a different look to the mobo, and possibly help with the case cleaning job. I personally don't think it even looks very nice.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
