bios HELP PLEASE! X470 AORUS GAMING 5 WIFI (rev. 1.0) not booting with weird status LEDs blinks
On 8/14/2023 at 6:28 AM, MistyAI said:Thanks for a reply, however, I failed to mention that I did attempt to do so, the problem is, there's no video output at all, so I'm not really sure how am I supposed to update it. I've read that some motherboard do support CPU-less BIOS updates, but I don't have such USB port on this motherboard. Theoretically I could get the 2700X back in the system to update it, but for that, I'd need to essentially rebuild both systems, which is suboptimal. If you know any other way around, please let me know ^^.
Unfortunately from what I can tell all of Gigabyte's b450 and x470 mobos don't support Q-flash (Gigabyte's version of CPU-less bios updating) so I'm afraid you would have to update the bios with the 2700x installed. You could possibly rent a loaner CPU from AMD which is something they used to do a while back in order to let people update their bios, though I'm not certain if that service still exists -聽https://www.amd.com/en/support/kb/faq/pa-100聽
聽
One other thing I will mention is to make sure your motherboard revision is the right one; either check the box if you still have it or check the mobo for the rev number having been silk screened on (likely the very top or bottom). Once you know which one make sure you install the bios from the correct mobo revisions support page to avoid any potential issues 聽
聽
If you need any more help just msg, also apologies for the delayed response xD
聽
