Hi, i’m new to pc gaming and it’ll be my first time building a pc soon. Anyways I have a question:
I’m looking to buy the MSI 3060ti Trio and i was just looking at its dimensions (it’s width was 14cm) - keep this in mind.
Now i checked up with my Pc case PCIE bracket and i seen that the width of the GPU is larger than the PCIE bracket, does this matter? Will my gpu still be able to screw into the bracket etc?
(the tape measure is the same size of the gpu for reference) 🙂
Any help would be appreciated
https://linustechtips.com/topic/1525951-help-please/
Just now, Dawidowski said:
does this matter?
No
Yes
It's normal for the gpu shroud to be wider and if it doesn't protrude your case glass (which it doesn't) you'll be fine clearance wise
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1525951-help-please/#findComment-16076427
16 minutes ago, filpo said:
No
Yes
Thank you for making this clear, sorry if it was a stupid question, im new to pc building lol.
Thanks again 🙂
https://linustechtips.com/topic/1525951-help-please/#findComment-16076457
Thanks again 🙂
No problem, welcome to the forum
Total: £1040.95
https://linustechtips.com/topic/1525951-help-please/#findComment-16076460
