compatibility Noctua offset bar compatibility question
Solved by brob,
1 hour ago, Shyguy873 said:Budget (including currency): $5000
Country: canada
Games, programs or workloads that it will be used for: gaming and blender
Other details
does anybody know if the noctua NM-AMB15 cooling offset mounting bar works with the ryzen 9 7950x with the noctua HN-D15 cpu cooler on it and the CPU not being de-lidded (i only know about it because of linus's video called "Noctua's New Cooler Voids Your Warranty...." and he talked a bit about de-lidded CPU's)?
No. See https://faqs.noctua.at/support/solutions/articles/101000484444. The NH-D15 requires NM-AMB12.
