My CPU is running way slower than it should, and it's causing everything to take forever to boot up, as well as rendering other things unusable. This wasn't happening a few months ago, and it seemed like this started happening all at once one day. Games and programs that I used to be able to run smoothly and easily are now having trouble even booting up, and in some cases, they are completely unusable. I've tried a factory reset on the computer and it didn't change the issue at all. What could be the cause of this, and how do I fix it?
https://linustechtips.com/topic/1522463-cpu-usage-not-up-to-full-capabilities/
Laptop?
Temperatures?
Which power plan?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
0.78GHz... What a familiar number. I experienced it before. Doing a factory reset of the operation system won't help because what failed is firmware. The CPU is Throttling for some reason. Sometimes it can be fixed by a hard restart (pulling out the battery), plugging and unplugging the power cable, removing the docking station, etc. If you search for "laptop 0.8 GHz" you can get many results on Google. I don't know the model of your laptop, but the following link is the one that solved my problem.
https://www.surfaceforums.net/threads/surface-pro-6-heads-up-on-slow-down-issue.24529/
And here is a thread in Linus tech tip forum that claims to solve this issue
https://linustechtips.com/topic/1180590-cpu-stuck-at-080-ghz/
Main Desktop:
Case:Jonsbo A4
CPU: Intel Core i9-12900K
GPU: Intel Arc A770 Limited Edition
CPU Cooling: Asus ROG Strix LC II 240mm AIO, with 4x Noctua A12x25 Fan.
Motherboard: Gigabyte Z690i Aorus Ultra DDR4
RAM: G.Skill DDR4 3600CL18 32GBx2
System Drive: Samsung 970Pro 1TB.
File Drive: Samsung 980Pro 2TB.
Media Drive: Intel S4510 3.84TBx2 (RAID 0)
PSU: Silverstone SX650G 650W SFX
Mini Home Server:
Case: Akasa Plato X8
CPU: Intel i5-8259U
Cooling: Passive Cooling Case
Motherboard: NUC8 i5BEH
RAM: 2400Mhz 16GBx2
Drive: Samsung 970Pro 512GB.
NAS :
Case: Jonsbo N1
CPU: Intel Xeon D-1521
Motherboard: X10SDV-4C-TLN2F
RAM: Micron 2400MHz ECC RDIMM 32GBx4
Pool 1: Data: WestDigit Red Plus 8TBx5 (RAID-Z1) Metadata: Intel P1600X 118GBx2 (Mirror)
Pool 2: Intel 670P 2TBx3 (RAID-Z1)
PSU: Silverstone SX300-B SFX
Mobile Devices: Microsoft Surface Laptop 4 (13.5-inch edition) | Microsoft Surface Go 2 | Samsung Galaxy Z Flip 4 | Samsung Galaxy Watch 5 | Microsoft Surface Headphones | Sony Linkbuds S | Sony Linkbuds
Just now, Alkaid said:
0.78GHz... What a familiar number. I experienced it before. Doing a factory reset of the operation system won't help because what failed is firmware. The CPU is Throttling for some reason. Sometimes it can be fixed by a hard restart (pulling out the battery), plugging and unplugging the power cable, removing the docking station, etc. If you search for laptop 0.8 GHz you can get many results on Google. I don't know the model of your laptop, but the following link is the one that solved my problem.
I've experienced this strange issue as well with a laptop. The solution for me was updating the firmware.
-= Topic moved to CPU's, Mobos, and Memory =-
Please be sure to post in the correct section.
 CHRISTIAN MEMBER
@Tiberius1638
Try running ThrottleStop 9.6
It was specifically written to solve the typical throttling problems that plague Intel based laptops.
https://www.techpowerup.com/download/techpowerup-throttlestop/
Post some screenshots of the main window, the FIVR and TPL windows as well as the Limit Reasons window. If you see a BD PROCHOT box lighting up red in Limit Reasons, that is the typical reason why a computer gets stuck at the minimum frequency. Try clearing the BD PROCHOT box on the main screen if this is your problem.
Another common problem is the power limits being set too low. Post lots of screenshots and I should be able to help you solve this problem.
All it takes is one 5 cent sensor to fail and this can cause your laptop to start throttling at its minimum speed. This problem is usually easy to fix when ThrottleStop is setup correctly.
