Laser is led focused point and optical is a wide point.  You will tend to get more of a smooth go from the laser mouse.  The optical sometimes tends to not know where it wants to read from.  If you had a choice I would go laser.  Just make sure you have a nice surface or mousepad for it.
Edited by Whiskers
Removing references to removed content.
https://linustechtips.com/topic/152233-help/#findComment-2033312
I wouldnt recommend a razer mouse i have one specifically the taipan and it has terrible tracking issues u might have better luck with them but i wouldnt give them my money again.
I don't like Razer mouses either I was using them as an example for laser mice. My mistake.  ;)
"Just another day at the office" Captain Price -Call of Duty
https://linustechtips.com/topic/152233-help/#findComment-2033921
