NO STORAGE DEVICES CONNECTED ERROR PLEASE HELP!!!!
Solved by Whatisthis,
If you don’t have ANY drives get detected in bios, that’s not a good sign.
Can you plug in your windows install USB and see if it detected? Some boards need the windows installer to load a driver in order for disks to start working. Launch the installer and see if it finds your disks. Usually this applies to nvme drives, but stranger things have happened.
Yeah, you want UEFI turned on / CSM turned off.
