4 minutes ago, kalelcool said:
im going on a 3 hour trip just wanna now how to travel with my pc thinking of taking my gpu and ram of and puting in a suit case so it does not move
I wouldn't bother removing RAM, but removing the GPU isn't a terrible idea, especially if its a traditional layout without a support bracket. The rest of the system should be fine comparably, even large CPU coolers. If its a SFX system, I'd just leave it as is or add in some sort of support bracket for the GPU.
Otherwise, I'd just seatbelt it in like a person while locking the seatbelt聽馃檪
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1520607-help/#findComment-16041300
There are tons of topics around this. If you are travelling with normal car, best place for the case is on backseat floor. Pad it in place with something big and soft, like jacket or towel. Removing components is not necessary unless you are expecting potholes or otherwise bumpy ride. GPU slot or tower cooler will move and harm sockets only if whole car moves on the full extent of suspension.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1520607-help/#findComment-16041708
