12VHPWR PCI-e Cable to 3 or 4 8-pins PSU ports?
Solved by Lurick,
Be careful, I had terrible issues with that exact CableMod one on my RTX 4080, although mine is a FE. The screen would randomly go black, the fan ramp up to 100%, but everything else keeps working in the background and I had to hard reset the PC to stop it. I've since swapped back to the Nvidia one and it's been solid since.
Edit:
To directly answer the question the cable should be of sufficient quality wire to handle the full power of the RTX 4090 on just 3 plugs as I've seen some companies (Corsair) even just doing 2x 8 pins for 600w cables and people having no issues provided the PSU is capable of driving the power.
