After finally building my first pc, everything is working other than that it wont detect my gpu (rtx 3060) instead it registers in device manager as "Microsoft 870", I have tried close to everything i can think of. Moving the gpu into a different slot, no red light on the motherboard. Checked the cables are seated fine, nothing works! Any suggestions on what i can do?
https://linustechtips.com/topic/1519291-newly-built-pc-not-registering-gpu/
What make and model is the GPU?
Did you install the drivers for it from the manufacturer?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
3 minutes ago, masoob said:
Ive got the
Asus Dual GeForce RTX 3060 V2 OC Edition GeForce RTX 3060 12GB 12 GB Video Card
Ok, yeah so from your pictures it's just set up with the generic Microsoft drive which is setup by Windows on a fresh install of Windows by default.
You'll need to install Nvidia GeForce Experience and install the latest driver for the GPU GeForce Experience will automatically detect the correct driver an help you install it. Once installed you will need to restart the system.
You will also want to get the up to date drivers for your motherboard and other hardware in the system from their manufacturer webpages as well.
It said at first that my windows isnt compatible, im windows 10 home but it isnt activated.
So it looks like(judging from the edge logo in the picture) you installed a very outdated version of Windows 10. Which depending on how outdated it is, may not be compatible with the new drivers from Nvidia.
If you go to the About Your PC tab in Windows settings it will tell you which version of 10 you are running. If it's out of date you will need to update your Windows 10 to the latest version. Then try the driver update again.
Use WinVer and post a screenshot here.
Specs of the system?
Sure you've not connected the monitor to the iGPU (motherboard) but the GPU?
Why do you lack the other drivers, forgot to install drivers (any)?
If you don't know a thing about drivers, maybe try something like Iobit Driver Booster. Just make sure to deselect everything else during the installation.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Why does it say your Game Ready Driver is from 2021?
Where did you purchase this GPU from?
ask me about my homelab
