So I recently bought a 4080. I was planning on upgrading CPU as well. I'm going from a 3900X to either a 5800X3D or 7800X3D.
Which would be the better pair or CPU. Also is the V-cache worth it?
The platform switch is not a issue as I have enough for the board and the kit of ram (dominators for AMD) I want (asus X670 TUF) just like my current. I've had good luck with the TUF boards.
My use case is streaming/gaming. Also everything would be on water/custom loop if that matters for this choice.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/1517787-cpu-upgrade-help/
Obviously 7800X3D would pair better with 4080, but the real question should be whether it's worth the additional cost.
This depends on what games you play and in what resolution, then how much do you value your money.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1517787-cpu-upgrade-help/#findComment-16021861
I have more than enough money for right now. Not trying to waste it of course but for an upgraded GPU might as well do it all at once and get a good paired CPU while I have it.
I play current, (cyberpunk, resident evil 4 remake) upcoming, (starfield, stalker 2 remake) older as well (assassin's creed games in chronological order) most single player games and minecraft. 🙂
Res is ultrawide 1440
27 minutes ago, micha_vulpes said:
I mean, the 7800x3d is a vastly better processor.
https://www.techspot.com/review/2692-ryzen-7800x3d-vs-ryzen-5800x3d/
If your primary use is gaming, then the 3d vcache is absolutely worth if you play CPU limited titles ( or resolutions)
Oh really? Thanks for that link.
So like minecraft? I do play that occasionally. Mostly single player games like the above I mentioned. My resolution is ultrawide 3440x1440
https://linustechtips.com/topic/1517787-cpu-upgrade-help/#findComment-16021882
5800X3D is just a drop-in upgrade and would probably be enough since you're on 1440p ultrawide.
It's similar to a 7700 to 7700X.
If it were a lower resolution or stronger GPU, I'd say the 7800x3d.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1517787-cpu-upgrade-help/#findComment-16021893
