How to check if your using AC standerd?
regios287
I currently got a Linksys EA6500 (AC1750) Wireless router, and my laptop is a Dell XPS 15z
I used to have a reg Wireless-N network card, but I upgraded to the Intel® Dual Band Wireless-AC 7260 Plus Bluetooth*
http://www.intel.com/content/www/us/en/wireless-products/dual-band-wireless-ac-7260-bluetooth.html
I installed the drivers for it on my laptop, I have been using it for about am month now on the 5GHz freq on my laptop. I dont see a speed/performence diff?
How do I know if I am using the AC band.
Linksys WRT1900AC Router
Cisco SG200-08 Gigabit Smart Switch
4TB WD My Cloud NAS Server
A better way is to open a cmd or powershell prompt and type in "netsh wlan show interfaces"
This will show you something like this:
There is 1 interface on the system:
    Description            : Intel® Dual Band Wireless-AC 7260
    GUID                   : 07aae3b8-8151-427e-b256-638b748dc6a1
    Physical address       : fc:f8:ae:6d:42:9b
    State                  : connected
    SSID                   : comstar5GHz
    BSSID                  : f8:1e:df:fd:01:b8
    Network type           : Infrastructure
    Radio type             : 802.11n
    Authentication         : WPA2-Personal
    Cipher                 : CCMP
    Connection mode        : Auto Connect
    Channel                : 149
    Receive rate (Mbps)    : 300
    Transmit rate (Mbps)   : 300
    Signal                 : 99%
    Profile                : comstar5GHz
    Hosted network status  : Not available
Laptop - Gigabyte P34G - 14" 1080p i7 4700HQ, nVidia 760M LiteOn 120GB mSATA, 1TB Crucial BX100, Intel AC-7260, 16GB Crucial DDR3 RAM, Win 10 Pro x64
Desktop - SilverStone Fortress FT02B i5 3570K EVGA GTX 570, Intel 120GB 520,  1TB WD Black HDD, 16GB Crucial DDR3 RAM, Win 10 Pro x64
Server - HP MediaSmart Server EX490, Core 2 Duo E8600, 2x WD RED 2TB, 2x WD RED 3TB, Stablebit DrivePool, 4GB Patriot DDR2 RAM, WHS 2011
I get:
The Wireless AutoConfig Service (wlansvc) is not running.
How do I know if I am using AC Standerd?
If you want to enable Wireless AutoConfig Service so you can run that netsh command do what it says in this post:
http://answers.microsoft.com/en-us/windows/forum/windows_7-networking/wlansvc-service-in-windows-7-can-not-be-started/5bdc7d1c-ce54-4add-b437-eb48f50f7436
Also it's not standerd, it's standard.
Ok once I do that, how do I know if I am on the AC band of my router?
I believe it would say something like 802.11ac in the Radio type section. Also if you're close to the router, you should see the Transmit rate and Receive rate be much higher (at least 433 Mbps).
  • 3 weeks later...
sorry for the late reply, but it says I am using N?
    Name                   : Wireless Network Connection 4
    GUID                   : 6364dac3-eb49-432b-9b26-f9f80eaf99bb
    Physical address       : 0c:8b:fd:5a:4a:c9
    State                  : connected
    SSID                   : MyNetwork_5GHz
    BSSID                  : b4:75:0e:67:be:ac
    Cipher                 : CCMP
    Channel                : 149
    Receive rate (Mbps)    : 29
    Transmit rate (Mbps)   : 29
    Signal                 : 99%
    Profile                : MyNetwork_5GHz
    Hosted network status  : Not started
Open the Network and Sharing Center. Click on the WiFi connection under Connections. Does the speed list as 867Mbps?
Nope. Still shows as 802.11n. Well, at least it does on all of my Windows 8/8.1 devices.
[spoiler = "My Computer Stuff"]
My ITX:
240 Air ; Z87I-Deluxe ; 4770K ; H100i ; G1 GTX 980TI ; Vengeance Pro 2400MHz (2x8GB) ; 3x 840 EVO (250GB) ; 2x WD Red Pro (4TB) ; RM650 ; 3x Dell U2414H ; G710+ ; G700s ; O2 + ODAC + Q701 ; Yamaha HTR-3066 + 5.1 Pioneer.
Things I Need To Get Off My Shelf:
250D ; 380T ; 800D ; C70 ; i7 920 ; i5 4670K ; Maximus Hero VI ; G.Skill 2133MHz (4x4GB) ; Crucial 2133MHz (2x4GB) ; Patriot 1600MHz (4x4GB) ; HX750 ; CX650M ; 2x WD Red (3TB) ; 5x 840 EVO (250GB) ; H60H100iH100i ; H100i ; VS247H-P ; K70 Reds ; K70 Blues ; K70 RGB Browns ; HD650.
Can you please explain a little bit more about what you mean "no speed/performance difference"?
Are you meaning via Internet Access (eg: youtube, downloading files, multiplayer gaming, etc), or do you mean over your internal LAN (transferring local files, etc)?
If your internet speed is basically less than 150 Mbps (Higher even potentially), then you will see ZERO internet speed differences over Wireless N. You SHOULD however see a lot of difference over your internal LAN when transferring files between computers, etc.
Now for the second bit, file transfers over the LAN, it will only go as fast as the slowest link. If the other computer/NAS/Whatever is on Gigabit Ethernet or ALSO on Wireless AC, then you should see a speed/performance increase. If the other device is on 10/100 Ethernet, or on Wireless A/B/G/N, then you will NOT see a performance increase, as the other device is acting as a bottleneck.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
    State                  : connected
    Cipher                 : CCMP
    Channel                : 149
    Signal                 : 99%
You're using the Intel 7260 card that I have. Seems there is a bug in the driver that will identify as 802.11n even if you're on AC (the old 16.x.x.x drivers didn't have this issue but they had a ton of other, more annoying, problems).
I updated to an AC router recently and as you can see the netsh shows as N even though the speeds are definitely AC:
    State                  : connected
    SSID                   : comstar5GHz
    BSSID                  : e4:f4:c6:02:ae:2b
    Cipher                 : CCMP
    Channel                : 149
    Receive rate (Mbps)    : 866.7
    Transmit rate (Mbps)   : 866.7
    Signal                 : 90%
Can you share your wifi settings for the 5GHz channel? Like what are your encryption settings as well as channel width? Also, how far away are you from the router cause your link speed is 802.11g level.
    State                  : connected
    SSID                   : comstar5GHz
    Cipher                 : CCMP
    Channel                : 149
    Signal                 : 90%
I got an Linksys WRT1900AC, and the download speed my ISP provides me is 25mbps down and 10mbps up
I am right in front of this router and I am doing this test
Attached is my settings
post-80998-0-20044700-1401804503_thumb.p
Edited by regios287
I am not 100% sure but your security setting could be what's causing the issue. Change it from WPA Mixed to just WPA2 Personal.
If that doesn't work can you also set the channel width for 5GHz from Auto to 80MHz?
There is no 80MHz optiion for the channel width?
----EDIT----
Is this true?
http://kb.linksys.com/Linksys/GetArticle.aspx?docid=c5db9fbfa0dc4601869f8e198b338874_Setting_up_the_Linksys_WRT1900AC.xml&pid=80&converted=0#wireless3
3.    Does the WRT1900AC support the 80 MHz channel width on the 5 GHz frequency?
Yes, the 5 GHz band supports the 80 MHz channel width provided that the Channel Width dropdown option is set to Auto.  There is currently no option to select the 80 MHz only setting.
Edited by regios287
----EDIT----
Is this true?
Wow, that just screams of lazy coding by the manufacturer (glad I'm using a Nighthawk with DD-WRT). Did changing the encryption help with your speeds at all? I know that anything below WPA2 Personal (using AES encryption) will give you bad speeds.
If I change the Encryption to WPA2 Personal, and I used that CMD command, I get 300mbps download and 300mbps upload, but if I check the Connection Speed in the "Manage Network and Connections" I see 300mbps as well
If I changed it back to Mixed, the CMD command gave me like 30mbps download and 30mbps upload, but if I check the Connection Speed in the "Manage Network and Connections" I see 700-900mbps if I am close to the router
Is that commend rlly accurate? I never knew I could check my connection speed in the Widows 7 Network Controls
The speed shown using the netsh command should reflect what Windows shows you in the GUI. Not sure why there is such a high discrepancy but I'm going to say the GUI is wrong as the AC7260 can't get a connection higher that 866Mbps up or down.
If turning on WPA2 Personal gives you 300up/down then I would say we're on the right track as that is the absolute top in terms of N speeds. Hopefully the next firmware update for your router will have better and more complete configuration options.
Are there any advanced wireless settings in the Linksys GUI?
As far as I know, no there is not
But shouldent I keep it on Mixed? I get over 750mbps in the Windows 7 info
I would see if you're actually getting that speed. Do you have another PC you can transfer a large file to or from? If not, do you have a USB drive you can plug into the USB port on your router and see how fast you can actually send data over? I'm going to say that in mixed mode you're not actually getting anything above the 30Mbps that netsh is showing.
I have tried transfering a 1GB file from my NAS server to my laptop over my 5GHz and I get about 25-40MB/s depending on the file
Something doesn't sound right. 750Mbps should be (without overhead) about 93MB/s. 25-40MB/s sounds more like a 300Mbps link speed.
What could be the issue?
Not 100% sure. The link speed mismatch you're showing between the netsh and windows' GUI is just plain weird as they should be identical. The NAS speed could be a function of the drives you have in there plus any kind of RAID you may have on there.
Try running a speed test using the tools mentioned in this article - http://www.smallnetbuilder.com/lanwan/lanwan-basics/31220-how-fast-is-your-network-five-ways-to-measure-network-speed . They should at least show what your link speed is.
EDIT: Apparently Intel just released an updated 17.0.3.2 drivers. These at least identify the 802.11ac connection correctly now in netsh.
