PC partpicker error not showing compatible 4X32 gig kit, am I wrong?
Solved by Oshino Shinobu,
7 minutes ago, Jovian said:Honestly I might just be better of buying a second hand LRDIMM ecc sever kit, what do you think?
Not 100% sure on X99's compatibility with LRDIMM. It supports RDIMM, but LRDIMM may not work.
As for PCPP, it's typicaly pretty bad with memory compatibility on older boards, especially with Xeons. Both the board and CPU should suport 32GB DIMMs.
