Budget (including currency): £850
Country: United Kingdom
Games, programs or workloads that it will be used for: 1080p 120Hz (in fps games) at High-Max settings. Games such as spiderman remastered, Elden ring, apex legends, Heavily Modded Minecraft
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://uk.pcpartpicker.com/list/j8zKFg
Would like it to last a few years at least, i appreciate the 8gb of Vram in 2023 is a bit of an issue but its cheaper than the rx 6700xt by a decent bit used. Was also wondering if it can run a modded minecraft server as well as play it at the same time? doesnt need to but would be helpful if it did. If i really need to spend a bit more i am getting paid soon but i want that to go mainly to desk and peripherals so if you do want to make adjustments that go over then i can do that just not by a massive amount. Thanks in advance!
https://linustechtips.com/topic/1516325-double-checking-my-pc-build-choice/
If you really bought a GPU, then you should really try to improve your cpu. and change other components that's really not essential. But at least get a cpu with igpu, it would make troubleshooting much easier, when you have to.
PCPartPicker Part List
CPU: Intel Core i5-13400 2.5 GHz 10-Core Processor  (£209.99 @ Amazon UK)
CPU Cooler: Deepcool AG400 BK ARGB 75.89 CFM CPU Cooler  (£32.99 @ Amazon UK)
Motherboard: NZXT N5 Z690 ATX LGA1700 Motherboard  (£100.00)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£74.98 @ Amazon UK)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£34.99 @ Amazon UK)
Video Card: Gigabyte GAMING OC Rev 2.0 GeForce RTX 3060 Ti LHR 8 GB Video Card  (Purchased For £280.00)
Case: Deepcool MATREXX 55 MESH ATX Mid Tower Case  (£48.46 @ Scan.co.uk)
Power Supply: Corsair CV650 650 W 80+ Bronze Certified ATX Power Supply  (£57.99 @ AWD-IT)
Total: £839.40
Generated by PCPartPicker 2023-06-29 15:32 BST+0100
But if you haven't bought the gpu, then a 6700xt is still a better option at the same budget.
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor  (£159.96 @ Amazon UK)
CPU Cooler: Thermalright Assassin King SE 66.17 CFM CPU Cooler  (£24.00 @ Computer Orbit)
Memory: G.Skill F4-3200C16D-32GTZ 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£55.84 @ Amazon UK)
Storage: KIOXIA EXCERIA G2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£38.39 @ Scan.co.uk)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card  (£321.59 @ Newegg UK)
Total: £806.23
Generated by PCPartPicker 2023-06-29 15:36 BST+0100
Another option is an All amd system with ryzen 7 and 6700xt.
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  (£167.66 @ Amazon UK)
Motherboard: Gigabyte B550M AORUS ELITE Micro ATX AM4 Motherboard  (£99.99 @ Amazon UK)
Case: Montech AIR 100 LITE MicroATX Mid Tower Case  (£37.94 @ Box Limited)
Total: £800.00
Generated by PCPartPicker 2023-06-29 15:55 BST+0100
Edit: I actually thought that your budget is only at around 800. Since it's 850, you can even lower the motherboard, as there are already reviews wherein 5800x3d works just fine with almost any mobo. But you might need a better cooler though.
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  (£263.00 @ Amazon UK)
Motherboard: Asus Prime B450M-A II Micro ATX AM4 Motherboard  (£64.98 @ Amazon UK)
Total: £860.33
Generated by PCPartPicker 2023-06-29 16:01 BST+0100
Edited by kitnoman
