Question regarding Custom ROM possibility
Go to solution Solved by Dr0idGh0sT,
Go to Telegram and search for groups for either of this phone, XDA may have linked such telegram groups as well. This really is not forum you should be asking for help. Even XDA is somewhat dead in this regard.
Hey guys, so I recently got myself a Xiaomi Redmi Note 12 Pro (4G), which is running MIUI currently. I am not fond of that software skin, so I want to custom rom my phone. I have done it previously, and I could say I have enough experience. My question is: will a Redmi Note 10 Pro ROM work on this phone, considering they have the SAME exact specs, and this is just a rebrand of the 10? Or could I encounter problems with a rom like that? On AIDA64 its codename is the same as the 10 Pro "sweet", but it could be wrong since the phone is kinda new. For the same reason I cand find a rom for my model, so I am looking for a 10 Pro one. Any answer is appreciated, thanks
https://linustechtips.com/topic/1515693-question-regarding-custom-rom-possibility/
  • 6 months later...
Hello there,
I have a galaxy A51, and since my phone is not that well supported I had to look at a looot of custom roms, and each time I've seen a lot of xiaomi phones in the supported lists, so what I can tell you is good luck on your journey, you'll enjoy it.
Maybe start with project elixir ( which is a ROM based on pixel os) it is clean with some extra features, and most importantly it is stable.
Another note : I'm sure the thing you'll miss the most is the xiaomi camera, but don't worry you can get that with a magisk module after you root your device ( don't worry, rooting is not that scary, it will help you get even more features).
So good luck to you, and enjoy.
