Budget (including currency): 2000$ excluding peripherals
Country: USA
Games, programs or workloads that it will be used for:  Gaming in general
Other details
This is my first time building a pc from scratch. I was wondering if this build would work
https://pcpartpicker.com/list/Hy7Jv3
https://linustechtips.com/topic/1515124-first-time-building-a-pc/
Country: USA
Other details
Do you already have a monitor and if so what is the resolution?
6 minutes ago, ChaosHetsu said:
No I dont have a moniter. I was planning on getting a moniter later but  I was just wondering if the parts themselves are good
What resolution monitor? Also what kind of games are you into? AAA adventure games and RPGs that are going to lean hard on the gpu for performance? Online shooters where you're more likely to be cpu bound?  Esports games where you're going to be 100% cpu bound and high end gpus are wastes of money?
8 hours ago, ChaosHetsu said:
Probably online shooters
Please press quote to get a response from someone. @Why_Me @SteveGrabowski0
So to clarify, you just dont have monitors? Peripherals are all good?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
You build is perfectly fine. It's actually one of the very few well put together systems i've seen lately. Just swap the Asus GPU for this one:
MSI GAMING X TRIO GeForce RTX 4070 Ti 12 GB Video Card
Boosts higher, stays colder and has generally better build quality. Just keep in mind that the GPUs in that class are still ridiculously overpriced. Even the 7900XT costs more than what it's worth, so not really a choice at that price tag.
Edit:
Actually on second thought you can fit a 7900XTX in that budget if you swap the 7800X3D for 7700X. It will look like that:
PCPartPicker Part List
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($308.50 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($34.90 @ Amazon)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5 g Thermal Paste  ($7.16 @ Amazon)
Motherboard: Gigabyte B650 AORUS PRO AX ATX AM5 Motherboard  ($249.99 @ B&H)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($104.99 @ Newegg)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($99.99 @ Adorama)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  ($949.99 @ Newegg)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($106.99 @ B&H)
Power Supply: *Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Amazon)
Total: $1992.50
Generated by PCPartPicker 2023-06-24 04:08 EDT-0400
Now you have the 2nd fastest gaming GPU after the 4090 and more than perfectly capable CPU. That will bring generally about 25-50%(depending on the games) more performance than the 7800X3D + 4070Ti combo.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
