Power Factor for modern PC components?
Solved by manikyath,
ignore the VA rating on UPSes, they all have a wattage rating as well, and your computer's power factor is good enough that the wattage rating is your limit, not the power factor.
EDIT: PS, i should also add, "power factor" is an AC power thing, the moment you're past the power supply none of it matters.
6
popularlion ·
Posted in Troubleshooting3 -
1
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
R_public ·
Posted in Networking15 -
apoyusiken ·
Posted in PC Gaming9
