Corsair K100 switches?
Solved by saintlouisbagels,
seon123's comment included pictures of where to look, so do us a favor and look at this comment instead of asking "could you mark it on the pic?"
In your original post you included a picture of the switch. That picture is completely blown out because the white LED is turn on. Request the seller to send a picture of the switch with the LED turned off. And obviously make sure it is a sharp picture so that you (or us) can actually read the branding on the switch.
I also asked you to send a picture of the switches on your keyboard since there seems to be confusion, and you completely ignored that. You even quoted it!
